Remote Hydraulic #2...
Anonymous-0
Thanks , Tires & Tracks for the pics..Good & clear.. Correct me if I,m wrong here.. The hose screwed into the housing behind the control valve lever has constant flow & pressure ? That hose would go to it,s own control valve ? & when that valve is in neutral the oil constantly returns to the diff sump thru the hose located behind the seat? Brian
(reply to post at 05:43:20 04/09/07)
Hi Again .. Just today I wanted to refer to your pictures you sent me on the hydraulic info we discussed & somehow they have disappeared . I,m hoping you can re-post them please.. Brian
