(quoted from post at 09:39:55 12/07/20) No, there is no oil in that pump it uses diesel to lubricate all the important parts. Even the Minimec, which has oil in it, is diesel lubricated and only uses oil in the mechanical governor.
ATF in the diesel can help to replace the lubricants removed from modern diesel, like the sulphur.
If your excess fuel button does not stay in, that points to a sticking or stuck rack.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto66102.jpg">
This is a standard style pump although the button is missing on the excess fuel shaft.
(quoted from post at 10:40:18 12/07/20)
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto66124.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto66125.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto66126.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto66127.jpg">
Thank you for the come back I took the side plate off yesterday and was able to work the rack back-and-forth without any issue here are some pictures that I took while I have a cover off little bit of rust here in there
