Fordson Tractors Discussion Forum |
1964 Fordson Diesel 5000 Super Major
Author |
[Modern View] |
Romies
12-04-2020 05:22:47
Snow blowing yesterday after five lanes the hydraulics quit completely. No lift bucket or lift arms . The pto shaft free wheels , will not engage. Any thoughts on my problem an possible fix. Cheers
Romies
12-04-2020 19:14:41
Re: 1964 Fordson Diesel 5000 Super Major in reply to Romies, 12-04-2020 05:22:47
Hi thanks that gives me a lot to think about
SkipperII
12-04-2020 16:34:54
The hydraulics do run off the pto on the super major. If the pto free wheels, you can pull the side cover off the pto housing, Where the lower end of the pto lever connects, shift it into gear, have someone turn the pto shaft, and see if everything turns up to that point. Stick a bar or heavy screwdriver in the gear, and see if that stops it turning. If it does, the problem is going to be in the clutch housing. The tractor will need to be split, if that's the case. If you do need to split it, make sure you put good wedges between the front axle and front bolster, those things will flip on you in the blink of and eye. If you do need to replace the clutch, majorman or I can try to advise you, they are a breed of their own. I can get the dimensions of the pilot tool for you, or majorman may have them.
Romies
12-04-2020 14:35:22
h8 no it is not to be touch I was told .it is straight up . Thanks
Romies
12-04-2020 14:33:39
Majorman
12-04-2020 14:13:38
The hydraulic pump drives from the rear of the PTO shaft so your problem is further forward I would think. Is it a "Live Drive" with a dual clutch? If so it could be a failed clutch plate. You could drain the gearbox oil and take the PTO selector off to check the gear and selector mechanism.
JLMac
12-04-2020 06:44:49
Is the PTO selector lever engaged? It's the lever in front of the clutch pedal.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Single front wheel assembly for 18-27 hart par
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
