Fordson major auxiliary remotes?
EmilioFM
New User
Want to add remotes to my major, was
wondering if anyone had recomendations. Was
considering the hv4111 or hv4121 but not
sure if they would work maybe majorman can
tell me.
I have no idea what your numbers refer to. A Major is a bit of a problem to fit remotes to unless you mount a separate block on the mudguard and take a line from the tipping port and one back to the filler cap.
It would be best to use a block with a relief valve that can be set slightly lower than the tractor relief. If the tractor relief blows you would have to stop the flow to the valve to get it to reset.
Hv 4121 kits are the ones that come with an adapter plate thas is added to the front of the valve chest under the seat. But i was not sure if it would fit or if someone has already done it.
