1952 Major with Ford 2701E Diesel
Mr.Major
New User
hello, looked at the above noted tractor today. It has the main frame from a loader as well as a front crank mounted hydraulic pump. The
motor turns over by hand but the tractor is rough. any comments on this combination?
Thanks.
The engine may be a bit too good for the Major. I would have liked it if Ford had put that engine in the Ford 5000 over here. apart from that should be a good combination with a fair amount of power.
