Major Rear Rim
JonV
Looking for a rear rim for a major. Current tire is 13.6x38, if that helps for which. Any ideas where I could find one (preferably in the northeast)?
What is problem with rim?
I have repaired 2 rims
First was on our JD 2040 where the previous owner
Was not a good driver and the outside rim was
damaged nearly all the way round so I cut off the
damage and welded the outside rim from a major
Wheel
Next was on our dexta where part of the outside rim
was badly corroded so I cut off the corrosion and
welded on replacement and this was done when I
Fitted new tyres
There s about a 5x10" section completely rotted away along the lip. Probably could be cut out and repaired, but wouldn t be too easy from the looks of it.
