Excessive crankcase pressure
Bairdfamily6
New User
Hello, I have a FSM with front loader and backhoe. I have alot of pressure resulting in oil coming out of the crankcase breather and pushing out the dip stick. The valve cover tube was plugged and got that done and cleaned and replaced the air cleaner still not luck. I currently have the decompression lever off so it doesnt blow oil everywhere. Any suggestions?? No water in the oil or oil in the water. Im lost here Thanks Mike
Is this something that just suddenly happened, or has it been gradually getting worse? Either probably indicates the need for a tear down. Gradual would show a possible need for rings and sleeves. Sudden, broken ring or rings, cracked piston, head gasket into an oil gallery?
