James Williams
I have pulled the motor and Im in the process of breaking the motor loose,Now I need some advice for removing the clutch.When I pulled the motor I see a bearing that fits into the flywheel and is on the transmission shaft,what holds the clutch in place,is there a nut behind the bearing.After I got done pulling the motor it turned dark,and I don't have any lights
