Company Logo Shop Now
TractorLinks.com
Fordson Tractors Discussion Forum
Fordson dexta help
226kevin
01-05-2020 12:06:28
Need help I have 1959 dexta diesel. The problem is that it won t move in gear but he PTO shaft will turn on would the clutch be bad or is something wrong in the transmission
226kevin
01-08-2020 15:03:40
 Re: Fordson dexta help in reply to 226kevin, 01-05-2020 12:06:28
thanks for all your help it s the first fordson I have had and don t know a lot about them. Where is a good place to find parts for them any help there would be greatly appreciated
226kevin
01-08-2020 15:01:15
it has the two holes. Does that mean that it has a double clutch?
Majorman
01-09-2020 01:07:12
 Re: Fordson dexta help in reply to 226kevin, 01-08-2020 15:01:15
Yes it is a "Live" (Double) clutch. It will come as a complete assembly, usually, you will also need pilot and thrust bearings. Watch the thrust bearing as the original was a double row of ball bearings and the replacement is a single row. This makes the bearing much thinner and the operating levers on the clutch will foul on the bearing carrier. I made a spacer to go behind the bearing and bring it forward to the correct position on mine.
Clutches are available here in England but should also be available in the US. You can also put new plates in but I have found this to be false economy as the linkage will be worn and you have to have the proper tools to rebuild and set it up.
226kevin
01-06-2020 13:29:15
I have also took the shifter plate of and nothing turns when it running even if you put it in gear
226kevin
01-06-2020 13:25:55
[quote="CVPost-derwen1959"](quoted from post at 08:38:00 01/06/20) Is it single or double clutch??[/quote
I don t know I just got it is there a way to tell with out splitting the tractor? There is not any adjustment left in the clutch linkage
Majorman
01-07-2020 01:11:28
 Re: Fordson dexta help in reply to 226kevin, 01-06-2020 13:25:55
The easiest way to see if you have a "Live" clutch is to look at the clevis where it goes into the clutch housing. If it has one hole, not a "Live" clutch, two holes = "Live " clutch.
If nothing turns in the gearbox then suspect clutch. They are not too bad a job to split with jacks and blocks as long as you take your time and jam the front axle with wedges to stop it flopping from side to side.
derwen1959
01-06-2020 07:38:00
Majorman
01-05-2020 14:33:42
Check that you have about 1" free play in the clutch pedal. The clutch may be bad but it would still turn the PTO if it had no load on it.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
