Primary gear box problems
Bill Dewey
New User
I am looking for a 24 tooth drive gear for the upper shaft, or a 24 tooth gear for the lower shaft. currently have 23 tooth gears for the lower shaft and upper shaft. The gears must be for a live pto gear box. The top gear I currently have is earlier set up and lower is the latest gear. When changing a gear, they must be changed in sets. this gear box has been running with a mismatched set and is starting to cause unusual wear on the teeth. I am hoping someone can help me as I am at a stand still in restoring this 1962 good ole fordson super major. Thanks, Bill
