Need help identifying the year of Fordson MD, (ID plates ?)
Lauri
New User
What year is this Fordson MD? The photo posted is limited and I will be posting more Fordson MD tractors detail as well as identification plates. I need instruction as to where these plates are located. I what to thank you in advanced for all the Time and Help! Looking forward to a smart restoration:)
[/b][/i]
The only plate on the tractor is on the firewall behind the engine up near the bonnet
hinge, however the serial number, depending on age, is either stamped under No.1 injector
on a machined area on the block or stamped on the clutch housing flange behind the starter.
All the castings also have a code that can give you an idea of the date, these are cast
letters and numbers like A14B or 3A14. There is one on the side of the gearbox housing near
the clutch pedal linkage. If you post these we can give you a date.
Thank you again for your instruction, I have finally be able to upload/posted more pictures but don't really know what I was taking pictures of but I'm sure you probably do. Does any of this information help you identify what year this FORDSON could be?
Hello my name is Lauri and you responded to my post concerning Fordson tractor I was trying to pin point the year of. You so kindly instructed me but this is what pics I came up with. I was wondering if you could look at the recent pictures I posted from the original to see if any of these pictures help come to the conclusion of the year. I want to thank you so much for your knowledge and your prompt response last time! Also I am new at forums and I'm not sure how to use them or find out within it how to get the information on step by step instruction 2 successful POST Etc. You being a long time member could you guide me to this information, again thank you so much!? Lauri. PS.this is my second reply to you and it didn't show up on my original post so I'm not sure if you're even getting this or if that's even how it's supposed to work?
Lauri
Welcome to YT
My knowledge of Fordson tractors is very limited . I think according to plate with #1289531 that according to SN chart in photo which can be seen utilizing home page on this forum is a "1954 model"
