would anyone know the yr of this engine
Hi all I'm new to this forum.
i wonder if anyone could help me in identifying this engine. it was taken out of a fm but it was not the original engine . it looks to be an early industrial engine with a decompression lever.
There are some cast codes on the block which are DDN F3 H2B. The h2b could possibly be dated 2nd June 1958.
There is also a stamped number on the block S135577
There is also a cast code on the head which is F3OB.
I would like to give it a full rebuild but i am unsure of the correct parts to order. i would like to get the parts from agriline products. Thank you very much indeed in advance.
kind regards dan
F30B is June 1958 so that would go with your date. "S" prefixed engines
are usually industrial units from combines, compressors etc. but use the
same components as the tractor with different fuel pumps and, as you say,
decompressors. I would be pretty certain that if you went for Power Major
parts you would be OK. Power Major because that was the current tractor in
1958. Most of the changes to the basic engine took place pre 1958 with
only minor tweaks through to the end of production.
(quoted from post at 15:30:14 10/27/19) I have heard stories about the quality of agriiline
products
Hi ok that's interesting could you suggest a company I could take a look at.
Kind regards Daniel
