high range gear noise
randysF
New User
I have a 54 new major that I recently purchased ,it has a gear noise in high range.it sounds to me like its in the pinion area.should I split the tractor between tranny and the rear diff. or is it the trans. considering it a high range only noise.
It is a bit difficult to judge what your noise is without hearing it. noise in just high range points to gearbox rather than rear axle. They are a pretty "clattery" gearbox and final drive anyway but they are very hard to break. I have seen 1400hp put through that back end without giving problems.
You could first try removing the gear selector plate just in front of the clutch pedal and visually checking the gearbox bearings, you could also put a bar between the shafts and see if anything moves.
Another thing to do would be to take the lift off and look into the rear axle, the final drives and dif can be seen. You are going to have to take most of this apart if you find a problem it is not just a simple splitting job.
