Company Logo Shop Now
TractorLinks.com
Fordson Tractors Discussion Forum
high range gear noise
randysF
09-08-2019 18:03:20
I have a 54 new major that I recently purchased ,it has a gear noise in high range.it sounds to me like its in the pinion area.should I split the tractor between tranny and the rear diff. or is it the trans. considering it a high range only noise.
Majorman
09-13-2019 07:28:34
 Re: high range gear noise in reply to randysF, 09-08-2019 18:03:20
It is a bit difficult to judge what your noise is without hearing it. noise in just high range points to gearbox rather than rear axle. They are a pretty "clattery" gearbox and final drive anyway but they are very hard to break. I have seen 1400hp put through that back end without giving problems.
You could first try removing the gear selector plate just in front of the clutch pedal and visually checking the gearbox bearings, you could also put a bar between the shafts and see if anything moves.
Another thing to do would be to take the lift off and look into the rear axle, the final drives and dif can be seen. You are going to have to take most of this apart if you find a problem it is not just a simple splitting job.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
