Fordson County Super 6
I have a 6 cyl engine from a boat and I'm not sure the differences between it and the original one for the tractor. I don't have casting numbers with me but if anything will help I can look it over tomorrow.
All those engines were basically the same apart from the injection pump and governor. The oil pan could be different and the oil pump may pickup from the front rather than the middle but otherwise should be the same. They were really a Super Major engine with two extra cylinders. Were used in trucks, combines of the era and industrial equipment.
I have the oil pan and a few other pieces from the tractor, not sure about the injector pump. The boat engine has the pump on it. I know the manifold is different, which I don't have.
