different simms pumps?
dale hood
New User
I hope the photo is attached;it's confusing. I have previously read about an oil reservoir at cambox of simms pump on dextas requiring motor oil; on my 2 there doesn't seem to be a fill plug or such thing. Do I just have pumps that don't have this? Any response is appreciated.
Dale t Hood
That pump does not have oil in it except when put into storage. Lubrication is done by the
diesel fuel oil. With the new diesel fuel I do put some ATF or two stroke oil into the tank
once or twice a year but that is my idea.
The later Dexta and Super Dexta tractors from 1962 had a Simms Minimec pump which requires
oil in the governor housing to lubricate the mechanical governor but yours has a vacuum
governor.
(quoted from post at 00:45:33 07/05/19) That pump does not have oil in it except when put into storage. Lubrication is done by the
governor.
Thanks for reply; yes the new diesel has no sulfur and is rough on engines w/o some addition.
I was told by a diesel repair shop to make a filler plug and periodically fill the pump. This would take care of the problem with low sulfur fuel.
