Dexta Oil Leaks
Hi All,
It is high time for me to fix the clutch on our Dexta!
I split her this evening, and there was masses of engine oil in there, and you would have thought that it was a wet clutch! Will this fix the problem properly?
http://nz.sparex.com/rear-crankshaft-seal-assembly-41494.html
I bought a steering main nut replacement, and it wouldn't screw on...any ideas why? Thanks!
Joshua
I have just installed this rope kit last night, and I am just starting to strip the engine down sealing all the oil leaks. Haven't quite got the clutch on, but hoping to finish it soon, but probably more than a month of work ahead of me as this is of to the side job.
Joshua
I also have dexta which leaked from the rear seal ... for a long time I used 15w/40 with no problem until one day the tractor needed oil but the drum was empty so I went to a neighbour but he had only straight 30 hd. So I had some of that... you may not believe what I say now but it is true when I put the 30 hd in engine and used it for a while the leak stopped so I carried on using. It and no more leaks
