Re: super dexta
what's the diff between dexta block 3.5 bore and super dexta block larger bore other than bore and type of Injection Pump? I have a block w/o head, turns over and measures 3.5 bore. I would like for it to go to someone that will put it to use. I'm in Race City USA (Mooresville NC). I understand that FASTENAL will haul freight for a reasonable fee. perbroatwindstream dot net.
yes // no cyl head // engine will turn over // I believe that it was parted out to get the cyl head // I believe that is a good rebuild core // location Mooresville NC // perbroatwindstreamdotnet p w brown
On my reply 3-19, I identified this is 3.5 bore so it is a DEXTA engine rather than s Super. I believe that the difference between the two engines is the cyl bore and mechanical injection pump. Noticed you are on the East coast somewhere and I shared my location. The crankshaft would be the same in both engines. As I said, I believe this is a good re-buildable core. Still has the oil pan installed and turns free. You pay the freight and IF after tear down the crank and block are to your satisfaction, what ever fair market value as I have no idea. I recomend that you visit // fordsontractorpages.nl // to determine making a 152 out of a 144. They will know. also, I included my email in the earlier post that is easier to use. Best Regards pwb
