Super dexta clutch location
Is this the normal height for the clutch pedal seems awful high
(quoted from post at 15:31:56 02/16/19) Is this the normal height for the clutch pedal seems awful high
go online you can download the complete service manual free. the clutch height and adjustments are spelled out. you need to know if you have single or double clutch. it tells how to determine. if you can locate the down load send your email and i'll send to you.
you dont happen to have a spare block and crankshaft available?
Your clutch rod clevis has two positions for linkage setting. It looks to be in the live pto position. For the pedal to be that high, I'd be inclined to believe the adjustment is about used up.
