Super major
Kip2
I bought a super major last summer it's the us version decals say ford 5000 diesel I put the agriline power steering kit on it I like the tractor so far the hydraulics seem slow I bought 10 gallons of 30 weight to change the hydraulic oil but haven't got around to it yet what's in it is kinda milky does it have filter if so where I also need double act remotes if I plumb my single remote hose into a double acting open center generic valve and run the return line back into the rear housing will this work Thanks
Hydraulic flow is around 4 gal per min. The filter is a washable metal one in the bottom of the rear axle housing, If you look underneath and find the drain plug there is a plate with four bolts in. Remove this plate and the filter will come down with it. Be prepared to get very oily! Yes, you will be OK running your dual valve as you describe.
