Dexta missing live pto front thrust washer
1960 Dexta with live pto doesn't have the thrust washer that sits between the drive gear and front bearing. It's part # C7NN-B777-A in the parts manual. What can I use to replace this part? Anyone have the dimensions that I can take to a machine shop, or one to sell? Thanks.
Number subs to C7NNB777B, appears to be still available from Case New Holland, about $30.
Dimensions shown are: 26.67mm ID x 30.96mm OD x 4.83mm Thick. (A little over .019" thick.)
I'm surprised at the thinness. There is a gap of 3/8" between the front hub of the drive gear and the bearing. Do you think the gear should move back and forth that much?
(quoted from post at 05:56:25 01/01/19)
Something sure seems odd, there, but I have no personal knowledge of that area of a Dexta!
