Super Dexta parking brake
Mrprez
New User
My tractor does not have a handbrake, but it does have the little handle under the seat that acts as a parking brake. The problem is, the handle won?t move. It doesn?t look like it is installed correctly as it is below the shaft and not above it like shown in the operators manual.
Is it possible to add a handbrake?
1964 Super Dexta.
Sure, here?s what it looks like.
<img style="white-space: nowrap" src="https://www.yesterdaystractors.comhttps://www.yesterdaystractors.com/cvphotos/cvphoto1228.jpg"/>
That's what I thought. Mine is the same way. If you depress the brake pedal all the way down, then flip that little handle forward, it will slide the teeth forward on the handle. Then, let off the brake and the pedal should stay down.
<img style="white-space: nowrap" src="https://www.yesterdaystractors.comhttps://www.yesterdaystractors.com/cvphotos/cvphoto1256.jpg"/>
No luck. The thing moves up and down with the brake pedal, but I cannot get that handle to move any which way. Guess I'll have to live with that.
