LarryMaine
Just bought a new Fordson F, I think it is a 1925, but something is strange. Serial No. on right side of engine just under the head is 478766, indicating a US made tractor in 1925. BUT, stamped in on left side of engine block is "MADE IN ENGLAND" under that is "N 6015 KR", under that is "J", under that is "Fordson", and under that is "X". This stamping is on the engine block, the same block with the serial number on the right side. I don't understand how a 1925 built tractor has an engine made in England. Also, the two bung fuel tank says it was made in the Irish Free State. ( I had assumed that this was a replacement tank simply because none were made in 1925 in Ireland). There is no separate gas tank, but the air washer still has the two bolt holes where a gas tank could be attached. The patent casting on the dash goes through 1922. It has a Holley 295 carb (by the way, when were these introduced ?). The tractor is painted a dirty white, not gray. The dash sides are not drilled for fender hardware attachment, and finally, although it has the standard internal magneto, it also has a WICO Series A High Tension Magneto. Can anyone help me understand why the engine was made in England with a 1925 period serial number, what year was the Holley 295 carb used, etc. Thank you so much guys, I really do appreciate your time and effort. I am only able to access the web in the evening, so give me a day to respond to any clarifications or questions you may have for me.
