Super dexta power issues
Kpass
New User
I have a Ford super dexta, it has issues staying running wile I'am working with it I.e. Mowing,disc etc. I changed the file filter, cleaned out the governor filter bled the fuel lines. It seems to run just fine when you are just driving it around but when you start to work with it it bogs down loses power and some time stalls out. I'am new to this tractor and looking for some advice any and all you be greatly appreciated.
Thanks In advance
A Super Dexta has a mechanical governed pump so there is no breather to clean. From the
information in your post I would suspect you have a Dexta with a vacuum governor not a
Super Dexta.
Make sure you have a very good flow of diesel from the fuel tap to the lift pump as there
is a filter in the fuel tank, in the tap, which is a beast to clean. Usually means
removing the tank to get it out.
Then check your air cleaner and the wire filter elements. Gunge gets drawn into the wire
mesh and can restrict air flow. Does your tractor blow black smoke as it bogs down?
Brian
