FarmerMike1
New User
was told its a 1962 power major. 4 cylinder diesel. I got it and the arms were stuck in the up positon even with pto not engaged. checked oil and it was milked with water. pulled top drained water and oil, and cleaned entire case front to back. cleaned top out and cylinder really good. relief was stuck. got relief unstuck and working as it should. put fresh oil in and spun shaft by hand and pump shoots oil out of supply hole excellent. put cover back down and operated. had a tractor pull rig on it and arms were under it when they went up it was strong enough to brake one of the lift arms. removed lift rig and cleaned arm up and welded back together. lift didn't work again mowed for about two hours not working the lift. next day the lift was working agin. parked with arms 1/2 up and left for a day. it bled down and hasn't worked since. what am it missing? pleas help.
