Order Ford 860 Parts Online
Re: 860 Transmission Questions
Bryan
07-05-1999 09:38:33
The only one I can help with is the 4" X 4 " plate. It is only an inspection plate for the clutch housing. If there is oil leaking from around it, you either have a rear main seal leaking or the front transmission seal is leaking. You can remove the plate without draining the transmission.
