I have a 5 speed 860 I bought about a year ago. I'm in the process of repairing a number of minor leaks here and there, including several associated with the transmission. I have several questions regarding this transmission:The first is in regards to the oil or fluid to use in this unit. The service manual (which I own) suggests using "Mild Extreme Pressure Lubricant SAE 80". What might be a modern equivelant of this fluid? I already have five gallons of a Shell "Premium AQ Hydraulic Oil". Will this be adequate for the transmission? Second question... On the bottom of the transmission case, to the right (as facing the front of the tractor), slightly forward of the drain plug there is a square plate attached. I can find no reference to this plate in any of the service material I have. This plate, which is about 4 inches by 4 inches, is attached with 4 bolts. There is oil seepage from around this plate. My thought has been to drain the transmission oil, and while the unit is empty, drop this plate and replace the gasket at the same time. Will this work as I think it will, or would there be problems if I pull this plate off or other issues to be aware of? BTW, what's this plate for? Last question... On the left of the tranny are three "plugs", which are described as "shift rail spring seats". There is also oil weeping from two of the three plugs. Again, I was thinking after draining the transimission, remove the two offending plugs and replacing the gaskets (I tried snugging them down but that didn't stop the leaks). Can these plugs be removed in the context I describe, the gaskets replaced and reinstalled without creating other problems? Thanks in advance! Kelly
