Order Ford 971 Parts Online
Re: 1971 Ford 2000 battery problem
Dave
06-29-1999 04:57:05
Before you throw away your generator there are some points to consider.
On alot old fords of this age the tach was driven off the end of the generator. You can do a simple voltage test to see if the generator is working. With the engine running at speed voltage at the battery terminals should be 13-15 volts. A simple volt meter from Radio Shack can check this.
