Order Ford 801 Parts Online
Re: 801 Select-O-Speed
Ron Gilmore
06-25-1999 11:26:43
Jon,
I have the same problem with mine. I have an 881 and ident symptoms. I found it was the control pistions on the top of the tranny. The guy at the local NH shop said I should get the valves honed. I just plain cleaned them and it worked fine for about 2 weeks and then the problem started again. I took it apart and found that because when the tractor sits it get a very small amount of condensation on these since it is above the oil level. I find that I just let the tractor idle for about 15 minutes and it works fine for the past 6 months or so. Hope this helps....
