Sos rebuild kit
scott-ohio
06-13-1999 19:23:47
where can a guy get seal and or rebuild kit for sos? this trans is leaking at the distributer or the main shaft - under the valve body
Bern
06-14-1999 12:27:15
 Re: sos rebuild kit in reply to scott-ohio, 06-13-1999 19:23:47
There are no "rebuild" kits available for SOS transmissions. There are, however, gasket and seal kits still available for most models. See your local New Holland dealer.
Ron Gilmore
06-25-1999 11:34:32
 Re: Re: sos rebuild kit in reply to Bern, 06-14-1999 12:27:15
I ordered a main seal from the NH dealer without a problem for the main. It cost me about 8.50. The only problem it doesn't work as good as the orginal... I measured the shaft and it's with-in tolerances. I know now why the mechanic before me added some silicone to the back side! I figured I'd replace it since it looked doctored.... I should have kept with the saying "IF IT AIN'T BROKE DON'T FIX IT" ... but I did... so next time I have it apart I'll doctor it and it will be fixed. .... Just my opion and experence.... Oh it worked fine for 3 years before like this....so...
