Order Ford 2000 Parts Online
Re: F2000 Remote Hydraulic connecting
Sean in PA
11-20-2023 10:06:36
With an HV5902 adapter plate, you DO NOT need a diverter valve. The instructions that came with the plate should show you how to hook things up. You also DO NOT need a Power Beyond sleeve in the loader control valve if the only thing you are powering with the adapter plate is the loader. Adding a Power Beyond sleeve to the loader control valve is only needed if you wish to also power another implement downstream from the loader. All you need to do is connect the P port on the adapter plate to the power input port on the loader control valve., and then you connect the Return port of the loader control valve to the PB port on the adapter plate, and then you plug the third port on the adapter plate, which I think is labelled "R". If the diverter valve is still there on top of the adapter plate, simply push the knob in and leave it there.
