Order Ford 4000 Parts Online
1962 4000 Industrial - color for front loader
zoomjay
11-19-2023 18:45:12
I have a 1962 Ford 4000 Industrial with a front-end loader. Tractor is gray/blue, although the loader is a pale yellow color. Does anybody know the correct name or code for the loader? It is a bit rusty and I would like to touch it up (stuff you buy off of the shelf is too yellow).
Thanks
Sean in PA
11-23-2023 08:01:10
 Re: 1962 4000 Industrial - color for front loader in reply to zoomjay, 11-19-2023 18:45:12
It might not be a stock color, but that code should tell any PPG dealer how to mix it.
zoomjay
11-20-2023 15:34:21
Looking at the PPG website.. looks like that color does not exist. Any ideas?
IndFord
11-23-2023 04:51:16
 Re: 1962 4000 Industrial - color for front loader in reply to zoomjay, 11-20-2023 15:34:21
I had this tuck away in a file... http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=582891
showcrop
11-20-2023 05:35:48
I am pretty sure that at the time that it was called "buff" yellow. It certainly rocked my world when suddenly my gray and red Fords changed color.
IndFord
11-20-2023 05:44:44
 Re: 1962 4000 Industrial - color for front loader in reply to showcrop, 11-20-2023 05:35:48
Thank you showcrop, I could not remember buff. I seem to recall someone had posted up a color number a while back. I did a search, but a lot of the older posts seem to be missing. I will have to look through my notes and see if I even jotted it down.
IndFord
11-20-2023 05:23:39
Hello,Depending on when in 1962 it was built, Prior to July 1962 it would be either a 4040 (Heavy Industrial) or 4030 (Light Industrial), both would come in the maze (light pale yellow) & red paint scheme. If after July of 1962 then it would be either a 4140 (Heavy Industrial) or 4130 (Light Industrial), both would come in the maze (light pale yellow) & blue paint scheme. Someone (maybe TJ) had posted up the maze color number on this site a while back. Loaders were painted in the Maze color.
IndFord
11-20-2023 05:58:02
 Re: 1962 4000 Industrial - color for front loader in reply to IndFord, 11-20-2023 05:23:39
This was from Tony The paint color is called Buff it is a Pale Yellow not Ivory . It is used from 1960-1965 on the 4 cyl. Industrials and the 1965-1968 3 cyl. tractors , The PPG Paint Code is DCC82831ALT .
