Company Logo (800) 853-2651 Shop Now
Order Ford 660 Parts Online
Cost to over haul 1956 Ford 660 PTO
Satohbill
01-24-2023 10:26:06
i HAVE A 1956 Ford 660 and the PTO quit working. I cannot turn it with my hand and it does not spin when engaged. What am I looking at for repair and cost of repair.
Tim PloughNman Daley
01-28-2023 05:33:52
 Re: Cost to over haul 1956 Ford 660 PTO in reply to Satohbill, 01-24-2023 10:26:06
Have you engaged the PTO Lever? Sometimes it is the basic stuff that baffles us. OOPPSS...forgot to turn ign key ON or OFF; forgot to turn Sediment Bulb Valve ON or OFF; forget to check oil levels...just saying.
Tim Daley(MI)
showcrop
01-25-2023 05:32:28
I doubt that the bearing could seize up because something ahead of it would have to be apart. Like Steve posted take the cover off and operate the slide sleeve back and forth manually and see what goes on when it is ahead vs. when it is slid to the rear.
stevob671
01-25-2023 04:33:13
If while not engaged you can not turn it by hand, I would say best chance that the rear bearing is locked up. Pull the side cover off (that has the PTO lever) and see if anything looks out of the ordinary inside though if you can engage and disengage OK I suspect no issue there. If the rear bearing- 4 bolts at the rear and the shaft assembly should pull out the back. Can't tell you what the cost would be depending on do it yourself or shop time...hopefully bearing and seal and oil would be Parts cost.
Today's Featured Article - A 1937 John Deere Unstuck - by Gary Hickman. Here is my story of how I got the pistons out of a 1937 JD B that the engine had been stuck for about 14 years: About 12 years ago my Dad gave me one of the tractors I ran as I was growing up on our farm in central Nebraska. The engine on this tractor, a 1937 John Deere "B", had been stuck for 2 years before he gave it to me. This last spring (1999) I hauled the tractor to our 2 acre lot in St. Libory Nebraska where it joined my antique machinery collection, at that time a 1929 Caterpillar T ... [Read Article]
Latest Ad: John Deere 420 W 1956 with full hydraulic Superior loader.. power steering, direction reverser, touch o magic,3 point, Pto.. Great sheet metal. Runs no smoke. May be a original yellow from factory.Decent tires. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
