Add Loader to 1974 Ford 4000
Pcamper
New User
I have a 1974 Ford 4000 Diesel, I have recently purchased a GB440 loader to attach to my tractor. I know Great Bend was bought out but I cannot find any information at all on this loaders hydraulic requirements. Im wondering if the on board hydraulics of the 4000 is sufficient to operate the loader. The expense of adding a forward pump and reservoir seem to be quite expensive. Any advice would be much appreciated.
The tractor's hydraulic system will run
the loader. Pressure is adequate. Flow is
on the low side, though... the loader will
be slow.
The tractor's hydraulic system will run the loader. Pressure is adequate. Flow is on the low side, though... the loader will be slow.
Great Bend was bought out by Bush Hog Co. In late 1990s. Loaders were given different but similar model numbers. You may find more info by searching Bush Hog.
