New to me 3600.
New panel. Tach / hour meter work. Fuel & Temp do not read. I doubt the warning lights are functional but don't know.
When I turn the key on, I have an idiot light in the lower left which is bright when the key is turned two clicks to the right and dim when the key is turned one click right.
The starter has been rigged to a push button below the ignition switch which is hot regardless of key position.
While I'd like a fully functional gauge panel, I'd be happy with temp . Anything else would be a bonus.
Do I start by pulling the wire from the temp sending unit and grounding it to see if I get a reading? If nothing, do I assume it's the sending unit or is there another way to check the panel gauge?
Thanks
Thanks
