sony224422
I bought my 4140 not running and have gotten it back together. One issue I am fighting is the front hd pump hub keeps letting the drive yoke slip out. I tried buying a new hub, but I can t find one with a set screw. I m not sure if they are supposed to have one or not, but the one on there now does. The threads don t go all the way through though for the set screw, so I m not sure if it s for something else. It s also the square style, I m not sure it s original. I tried replacing the rubber inserts but the yoke slipped out again still. What am I doing wrong?
I did have the yoke off the crank and pump at one point, is it possible it s too far forward on the pump shaft?
Or that I have the wrong hub
