robilmichael
Hi, I have a 1957 Ford 850. In the winter the 3 point system takes several minutes after the tractor starts before I get any
movement in the system. Once it starts and operates when the tractor is warm the system works fine, but it does hiccup a bit and
will leak down relatively quickly. My Jubilee has instantaneous response in the system even on the coldest days and does not
hiccup or leak down, but I did replace the o rings on the lift cylinder several years ago with the rubber ring and leather
washer. I suspect the leak down in the 850 is from the need for new ring system in the lift cylinder. Is there some way to test
the pump on the 850 for a leak or low pressure, or should I just rebuild the pump?
Thanks for any advice
