65 ford 3000 gas fuel shut of broke
Just purchased 3000 tractor gas .3 cyclinder.the owner snapped of plastic screw ..I
see a wire clip I can take out and replace just the screw .I would rather not screw
out of tank scared . if I purchased a new shut of would the plastic screw be the same.
The replacement Ilast got has brass stem for shutoff and proably not the same size or thread. If replaced 40 or so years ago it was plastic from Ford. Back then could drill hole and ez out or drove small screwdriver in and turn out.
I have purchased tank valves for the Major/thousand series from YT in the past, with good results, and they are reasonably priced.
Thanks napa has one .and it looks like it has the u clip to remove stem.sperex brand .maybe help someone .hope I can screw out broken plastic piece .and not remove from bottom tank.
