1963 Ford 2000 Clutch Pedal Bushing HELP
Dan
I inherited my dad's 1963 Ford 2000 4 cylinder with a 5-speed transmission. Was in the process of adjusting the clutch and of course the pedal bushing is wore slap out (still has the FORD logo on the bushing). However, after a full day of trying to find this part on the internet I am stumped, it appears these bushings are no longer made as all I find are for the later 3-cylinder models. I do not yet have a parts manual for those years as I have always worked on 9Ns, 8Ns, and NAAs. Can anyone with this year's parts manual please give me the part number to this bushing? Maybe I will have better luck searching for the actual part number.
Note - this IS NOT the 3-cylinder model, this is the early 4-cylinder 134ci engine like the NAA. Also, this is a 5-speed transmission, which will be different from the normal 4 speed version. The bushing looks to be right at 1 OD and about 1-13/16 long with a grease hole offset to one side. Not sure of the spec ID as it is worn.
TIA,
Dan
TIA for any assistance locating a replacement.
It is avaible. CNH # 47460975, old # NDA 7508 A. This site may catalog it, they do the brake shaft bushings under the R/A center hsg.
Shaun - this bushing looks like the cross shaft bushings (the shaft that runs through the tractor and has the fork attached). I need the clutch pedal bushing, the one the clutch pedal pivots on.
That part number looks to be correct. Now I know why I have been having such a hard time finding it - it is No Longer Serviced. Drats! Guess I will have to live with a wobbly clutch pedal.
Thanks again,
Dan
(quoted from post at 17:00:43 01/05/23) Can't a generic bushing be made to work?
Yep, the original bushing is steel but could get a bronze one in a pinch. Atlas Bronze carries one that is close and can probably be fitted.
