sony224422
I know, I know, everyone asks this and there are a bunch of old threads. I have read a lot of them, but now it seems even more so that NH has made it even muddier for knowing which fluid to use.
I know I need NH134- however, when I search that, I get a couple of different things coming up.. from NH.
MultiGrade 134 Hydraulic Transmission Oil - SAE 10W-30 - 5 Gal./18.92 L #73344281
and I also get this to come up (it does have the different NH-401B)
Multi-G 134 Fluid (NH-410B)
A Multi-Purpose hydraulic / transmission fluid
Multi-G 134 is a single fluid for hydraulic systems, transmissions, differentials, wet brakes and PTO clutches. A high quality hydraulic oil that is truly all-purpose. Designed for use in an ambient temperature range of -5F (-20C) to 120F (50C).
Multi G-134 hydraulic fluid is a multi-purpose fluid for hydraulic systems, wet brakes, various PTO clutch systems, differentials and transmissions in farm tractors. It creates a rust- and corrosion-resistant lubrication, and is slow to oxidize. It is a medium-duty oil, with good anti-wear properties. The specifications are the same or higher than those for many other oils, and it can be used as a replacement for several, including Ford Tractor M2C134B, M2C159B2, Stieger Hydraulic Transmission SEMS 17001, White Q17001 and Allis Chalmers PF-821XL.
Am I looking at either of these? Or better off getting the top one or is something from tractor supply good enough now?
