Ford 4000 SOS 3cyl servo #1
While replacing the gasket on the cover plate for the #1 servo my helper moved the small piece on the end of the push rod and it disappeared (fell) and I can't find it now. I suspect that it is in the bottom of the transmission. Do I have to remove the steering housing to find it? As of now I can not find a good diagram of what the piece or mechanism looks like.
Is Key# 33, part #C5NN7N158A what you are looking for?
wore out thank you for that diagram. Item # 33 is what I am missing. Maybe with a magnet I might be able to retrieve it but if I can't, can it be done by removing the steering column?
I m not sure about #1 band but I dropped the band pawl off of # 2 band in the SOS I had
Had to do a rear split and disassemble part of the back section of the trans to find and reinstall the pawl
This post was edited by Destroked 450 on 01/04/2023 at 03:10 pm.
Indeed you can access the front components with the steering box out. You can't pull them out, but you can
get your hands on them. Re-installing a dropped strut should be a piece of cake.
