I bought someone else's project a few years ago. Two years ago I did an inframe overhaul. Reconditioned rods/new bearings, sleeves, pistons, full head rebuild. At the time I tried to get studs to replace the tired original head bolts, but they were out of stock and would not be available for at least a couple of months. I went ahead and put it back together with the original bolts.
I used the tractor lightly (it's basically my spare) and then at about 30 hours on the overhaul tilled and disked about 3 acres. The machine ran well, rings were seating, nothing like a fresh engine.
Then just driving across the farm, not working, it began to run poorly. No compression on #2 and #3 cylinders. Head gasket failure. I parked it away until this week when I had shop time to work on it.
Deck is flat.
$134 in US made nuts, washers, and studs from ARP - good stuff.
Studs and new head gasket in position.
Torqued to 70 ft/pounds in 4 increments using the prescribed pattern.
Took the opportunity to install a new fan shroud. Old, cut up one would occasionally contact the fan.
I got it running and up to operating temperature tonight. I will retorque the nuts, adjust the valves, button it up, and replace the gas tank and sheet metal tomorrow.
I have more projects in line...
Deck is flat.
