cjwilson78154
From what I have found here and elsewhere. my tractor is a Frankenstein. Rear end has the casting on left side of: D4NN 4024A.
I got the tractor running and attempted to pull a shredder for the first time. All went perfect. Shredded about 2 acres. Raised and lowered the shredder many times just to get the feel of position vs draft control. Got low on fuel and decided to come in and park.
Went out to finish the shredding and 3pt doesn't lift. No noises or straining. Just nothing. Front end loader works as it should. Anyone here that can shed any light, it would be greatly appreciated.
I remember I checked and added a bit of hydraulic fluid shortly after purchase 6 months ago. Have not changed the filter, which is below the left foot pedals. Can't now remember which plug to pull to check fluid level. I remember you pull a plug and fill from below seat. When oil dribbles out the plug's hole, it's full.
