Maine4140HD
1963 ford 4140 HD Industrial 4-cylinder gas.
I'm still having issues with getting the correct starter solenoid or a valid wiring diagram for 12 volt system. I installed a solenoid from yesterday's tractor 311007FR which they said was correct. I replaced the starter switch, 1-wire alternator (it was bad), the starter, and ignition switch.
The starter switch still does nothing when the key is turned on but I can jump the solenoid to start it. The PO provided a wiring diagram but I don't think it's correct, it uses the s terminal for the starter switch when it was actually connected to the i terminal. I'll attach it below for review.
I've owned it since July 2022.
If someone can tell me the correct starter solenoid part number and a wiring diagram for the series 4000 4-cylinder gas 58'-64' 12v conversion or equivalent tractor I would be very grateful.
Thank you
Thank you
