Ford 7600 Fuel Tank Removal Dual Power
Thought my fuel tank was leaking from the bottom where supply fitting goes in. Started disassembling and realized I couldn t get dual power lever loose to remove cowal. Anyone ran into this issue before? Thanks and Happy New Year!
I used a small tip for a brief period of time, never really had an issue with scorching the paint. If you
are concerned about that, a piece of sheet metal and some tin snips should be all you would need to fashion
up a suitable deflector.
