TractorDad3
Greetings and thank you for any direction you can provide. Just
attached the control valve pictured below. Wanted to bleed air
out of hoses so put nozzles on the ends. While cranking,
without placing the lever outside of its home position, noticed
hydraulic oil exiting one of the hoses. Double checked that the
valve was in the home position. Now scared to start the tractor
with pressure heading out a hose without using the valve.
Is this correct?
I am sorry for being a novice with this valve
Is this correct?
