Destroked 450
- Location
- Harned, Ky
This spring I had a clutch issue with my Farmtrac tractor that has the NH 3930 engine, the clutch is for a Ford 3600
We split it 2 weeks ago to find 2 of the pressure plate lever bolts had backed out damaging the threads in the levers
Local clutch shop took care of me replacing the complete assembly and upgrading it to a button disc
While baling hay this year the throw out bearing in the 6610 cab tractor started squalling, the tractor has 5000 hrs but it has seen a lot of clutch work baling and loading 800-1000 rolls of hay for the past 12 years
The plan was to get the 6610 in the shop to split for a clutch job as soon as the holidays are over, but today while working in the poultry barns the pto drive hub and possibly the pto input shaft stripped out on the 4000. Since the 4000 is used for winter hay feeding it ll go in the shop next for clutch replacement and possibly a transmission input shaft
I put a new clutch in that tractor 22 years ago
