FOMOCO Farmer
We got back to rebuilding the remote valves today. The #2 shuttle check in all three valves had no 0-rings present. Upon installing the O-rings and back up rings we discovered there is not enough space for an
O-ring and back up ring in the grooves they go in. What would you think is the problem?
You mentioned shuttle check #4. We have not attempted a teardown of this valve. Do you think we should?Thanks!
