Was a push button start standard on a 73 5000 diesel? I found an older operators manual online, but it's only showing a key start. The ignition switch I have can only be turned 2 positions, and it's wired with a push button to actually start.
I think either this ignition switch is not original, or more likely is just not turning correctly, since it has 5 posts which are all wired.
I want to replace this switch so I can power the manifold heater. I don't mind the push button start, but everything I've found so far says it should just be a key start.
