Noel Putman
Bear with me here. I know enough about turning a wrench to get myself into trouble.
I bought this tractor at auction and the lift arms would only lift about 4.
Pulled the lift cover and replaced the cam follower pin as someone on this site correctly suggested it was well worn out.
Put it back together and the lift arms wont move at all. I primed the pump but cant say I was overwhelmed at the stream coming out of the pump.
Also, when I removed the large bolt from the plate on the front of the lift cover no hydraulic fluid comes out. Maybe it is not supposed to. Throwing that out there in case it means something.
Thank you.
Thank you.
